1 - 3 of 3 Posts
GOT LIFT?
I bought my son some Altezza lights for his 08 Caliber for Christmas, we went out to put them on and me, thinking it would be a couple of bolts to remove found what appears to be a black plug of some kind. I was trying to pry on them to see how they go on, thinking this was some kind of a bolt cover but, figured I would stop before I broke one of them. Anyone change the stock lights out? What is this plug? Do these just pop off or is there another way to take them out?
Another thing I noticed is that these are suppose to be for a 2008 Caliber, his tail lights only have 2 bulbs > a combination stop/tail/turn and a back up light. These Altezza lights have a place for 3 bulbs > 2 red and 1 back up. Did they change these or are there some models that utilize 3 bulbs?
Thx.
Thx.
Your right about the tail light fixture,it is held in on the hatch side
by 2 pry out pin plugs.If you look closely you will see a spot to pry
with a small flat bladed screwdriver,they then pull/pivot towards the
outside of fender.
There was a change from '07 to '08 in the wiring for the tails,I have not
changed out mine but quite a few other owners have,I might suggest
you check out either of caliberforumS or caliberforumZ sites as many on
both these sites have done the mod.
GOT LIFT?
OK, thanks for the help, I'll try one of those.
1 - 3 of 3 Posts
