1 - 6 of 6 Posts
1976 Dodge D100 Custom Utiline 360 A-833 OD trans.
Does anyone have a schematic that shows the factory tach wiring set up? I happened upon a factory tach and would like to wire it in.
bherder gave me a good schematic a couple years ago, but it does not show the tach. I don't have a FSM and my Chiltons does not show it either. Just thought I would check here. Thanks
Discussion Starter · #2 ·
Anyone? There are about 6 wires coming out of the factory tach. I just need to know which one does what. Don't want to guess and fry the thing. I could probably figure out the lamps and such it's just the coil wires I'm unsure of.
Ron,
On page 8-135 of my '77 FSM, a schematic diagram for the tachometer is shown. Unfortunately, the '77 tach apparently used only four wires:
18 ga. white = ground
18 ga. black = signal from negative side of coil (goes through bulkead connector position #21)
18 ga. green = "ignition accessory" terminal from fuse panel
18 ga orange = illumination lamp (from under-dash harness connection)
Hope this helps!
Jeff
Fins
I'm an idiot there was only four, in which case yes that helps immensely. My tach matches that color code you gave. Thanks for taking the time to look that up. I appreciate it.
1 - 6 of 6 Posts
