fish on
How Many Turns Should Lvl Me Out. And I Want To Tighten Them To Raise Right? I Got My New Bilstins On The Way Should Be Here Thurs Or Fri
Thanks Chuck
yes turn them in evenly I did mine 4 turns to do the job 5 turns made the shocks bottom out do not back them off! if you go to far and leave them in an unloaded state they could unload by themsevles; if you do have to turn them back go a 1/4 turn past the point you want and then turn back in to the point needed! oh and for the record if you haul a lot of weight your arse will sag and make the truck look wimpy. this is what happen to me as I haul a lot of weight so I left the front turned up and added fabtech add a leafs and that raised the back up 2" so now when I am loaded I sit with about a 1 " rake
