1 - 12 of 12 Posts
now this rear end is 4 inches shorter than the stock chrysler 9 1/4. How would you make it work?, spacers? Also how would the u joint work? I also have a gm 12, and 10 bolt rear ends, will they work also? lmk asap. Thank you!!
-josh
· Built Not Bought
You could Run rear rims that have less backspacing. Wont be able to rotate your tires from front to rear.
As for the U joint, you may have to get the d shaft retubed to accept a larger U joint.
· The Legendary Cross Ram
Question: why remove a Mopar rear end for one from the General? I figure: if it works good, don't fix it.
Thanks.
· Built Not Bought
14 bolts are very strong and very cheap
· Hotty Toddy Gosh Almighty
His wasn't working well, that is why he is upgrading to a stronger unit with more cheaper readily available parts in case he breaks something else.
Okay. :)
Discussion Starter · #8 ·
but what about the width of the rear end?? would spacers do the trick??
· Built Not Bought
I personally wouldnt run spacers. Is you 14 bolt a Full float or semi float?
Discussion Starter · #10 ·
what are we talking about floating? both of my rear ends are limited slip
· Built Not Bought
In a semi float axle, the axle shaft transmitts power and supports the weight of the truck. A full float axle shaft only transmitts power, but does not support the wieght of the truck. Full floater is a stronger axle. GM offered the 14 bolt in both Semi float and Full float axles. 14 bolt Semi float also has a smaller ring gear than the full float
Discussion Starter · #12 ·
ok, now back to my original question, the width issue, im running stock rims.
1 - 12 of 12 Posts
