1 - 2 of 2 Posts
Rollin On 4:56's
What's Up All:
Been having some issues with my e-fan(blackmax 180 extreme). It's not kickin on, and I have found out that the controller needs replacement. So, I tried to hook up a switch for a bypass and it works, but if I run the fan with direct power(to battery), it runs at full speed, but if I hook it to a switch, it runs just ever so slightly slower. I need to have a switch hooked up for tomarrow cuz the wife needs her car at the same time I need the truck for the doctor. Why does the fan run slower from the switch? Is it the wiring or what? Any suggestions?
Got 2 Hemis
Considerably more resistance in the wire path through the switch. The switch probably isn't rated high enough for the load, either. What gauge wire did you use?
1 - 2 of 2 Posts
