This may be a stupid question but i have to ask it. I ve been reading on some forums and off road magazines about people disconnecting their sway bar when the go off road. I was wondering why people do this and if its a good idea, because with my lift came sway bar quick disconnects.
Unhooking the sway bar reduces the roll resistance, so you will get more articulation of the front wheels on terrain where you have a lot of opposite articulation i.e. all the weight on two diagonally opposite wheels. I got the RC disconnects extra with the 2" kit (because they were cheaper than replacing the broken ones with standard parts), they click a little on the road as they have some free play in them, but you'll have to use them as the standard ones are too short with a 5" lift. On mine they seem to make little difference, but with 5" taller springs at the front the rate will be lower and so it'll be able to flex well.
I found that disconnecting the sway bar makes a huge difference in the articulation department. I actually removed mine completely. I didn't notice a difference at all while on the street due to the spring rate of the Fabtech springs in my lift, but off road it made a world of difference. Give it a try and see for yourself.
I'll definetly try removing them this weekend and see how it works. Thanks for the replys
