I have a 99 Durango SLT 4x4. After reading several threads in this forum, I decided to remove the front sway bar to inspect and lube the bushings. I found a sticker wrapped around the sway bar slightly to one side that has what appears to be a part number and the word "LEFT" on it. This begs the question, how do you know the orientation of the sway bar? The ends are bent such that turning the sway bar over results in a slightly different orientation of the ends. I suspect the "LEFT" label should go to the driver's side, but it was not installed that way. Any ideas?
