1 - 7 of 7 Posts
Found a 1984 truck at the local p-a-p... Will I need the tranny crossmember??? Planning to get the clutch pedal/linkage etc... Anything else come to mind?? The donor is a /6, so no bellhousing... Thanks ill
Aka Force Fed Mopar
Does your truck have the longtail 727? Or the shorttail w/ a bolt on yoke?
i also have an a833 in my garage awating transplant when I can find a bell housing. to keep things simple im planing on using a hydraulic clutch.
I think someone told me i need a bell housing for and only for an a833 to a sb... can anyone clarify me?
I took the tranny cross member just incase, apparentley the drive shaft is the same size. take everything you possably can just to be safe.
Discussion Starter #4
A833 swap
The 727 is the standard long tail...
I've heard the same info on the bell housing(large opening for trans)... Iam thinking that you can swap the input bearing asm for a smaller one(A833)-to get around that problem??
4 Wheel Power Disc Brakes
I did a swap from a 727 to an A-833 OD in my '78 van about ten years ago. At that time it was hard to find a V-8 bell housing with an 11" clutch that fit the transmission.
Now thay can be found on ebay under "mopar transmission" from time to time.
Aka Force Fed Mopar
Nope, they don't interchange.
1976 Dodge D100 Custom Utiline 360 A-833 OD trans.
Bbodybill,
PM me if you want specifics. Been down this road myself.
Ron
1 - 7 of 7 Posts
