I have recently discovered a new issue with my 07 Limited 5.7. When I punch it and run it WOT, I'm getting a pulse/surge in my acceleration. This only happens when I run it Wide Open. It is as if there is something electrical is not getting through to the computer constantly that I desire to run it WOT. Best way I can describe it is it's like it jumping from 3/5 full to full throttle off and on.
Could this be something in gas pedal electrical contacts causing this or should I be looking elsewhere? I was thinking about taking off gas pedal and cleaning the contacts with some contact spray.
Has anyone else experienced this and found a solution?
My 07 Limited just hit 140k miles. Also, just recently had exhaust leak repaired. Was also thinking about doing a PCM/NGC reset but have yet to find the actual proper procedure for this particular line of Gen 2 Limited.
