1 - 14 of 14 Posts
Is it possible to remove a superchip tune from ecm without the tuner.The reason I ask is because my tuner went faulty and locked vehicle in tow performance setting and would not let me change it back,so I returned the tuner to superchips who then proceeded to wipe/reset the tuners memory erasing my stock tune that was in there.So I now have a working tuner but a truck that is still locked in tow performance setting.Whenever I try to tune vehicle I get error code E-43 as the tuner is trying to save stock tune from the vehicle which is not there.Any suggestions ?I live in the UK so taking the truck to a local dealer is out.
I would just have your dealorship re-flash your PCm back to stock. Then install the superchips like normal,
SPEED SAFE, AIR RAM
dang your screwed....lol.....how did it get screwed up in the first place???
Yeah thats a good question, how did you get it in the first place? I would think that your tuner company could tell you how to fix this. They must have dealt with somebody else who has had this issue.
Your gonna have to try and call some wrecking yards and get a computer from a Ram the same year as yours. Then you can swap that computer in and maybe flip flop them? I dunno anything else to do.
KB
ram-side
Where abouts you located ? Did you ever get this problem sorted out ? I have the same problem you got !!! going to see if the local Dodge dealer ... ha ha ha can reflash my Rams computer. I think I am stuck in a state of tune other than stock but dont know WTF it it !!!
Martin
YOu cant just install another ecu in your truck. If its like the srt4 then you need the vin flashed in it for it to work correctly.
HOw do you install a super chip? Do you have to open up your ecu? I know you cant do that on the srt4 cause its gelled inside and everything is soldered, no plug n play chips in there.
Dont know if the VIN needs to be programed in or not, it does not in my Jeep 5.9 so maybe on the newer engine "HEMI" it does. The superchip is a programe introduced via the OBD2 socket
Martin
ram-side
How FU**ING hard can it be ? there again its part of DC so that answeres itself :-(
Martin
Martin
Ah I see. I wish the srt4 had a setup like that! That ecu is bullet proof for the most part. hard to get into it. Way to advanced for a freakin neon.
1 - 14 of 14 Posts
