Well, it is stupid because I pretty much know the answer, but I just want to make sure. My mother owns a '97 Caravan, which I do most all of the maintenance work on. A few days ago, I was driving it, and noticed that the steering gets a bit stiff when making tight turns. I checked, and adjusted the pressure in the front tires (both were quite low) and that made a good bit of difference. I then checked the power steering fluid. It is low, and needs to be filled up, but my question concerns the color / smell of the fluid. All the power steering fluid I've ever seen in my life has been clear, and pretty much odorless unless it was burned. The fluid in the Caravan's steering reservoir is red, and smells suspiciously like auto transmission fluid. Is there some kind of power steering fluid I am unaware of that looks and smells like trans fluid, or did Chrysler use trans fluid in the steering, or did someone else at a later point use trans fluid in the steering? If it is some kind of steering fluid I have never encountered before, what is it called, do I have to buy it directly from a Dodge dealer? If it is trans fluid, is that what is supposed to be in there, and should I just top it off with more trans fluid?
I'm not having any other problems with the steering system, no weird noises, or leaks, and the stiffness just developed recently, and as I mentioned above, mostly went away when I corrected the pressure in the front tires. I am guessing that filling the steering fluid up the rest of the way will fix the remaining bit of stiffness, I just need to make certain that I"m pouring the right stuff in there.
