I have a 2006 dakota slt quad cab 4x4 4.7L magnum with 128000 miles on it.Last night I pulled into a parking spot when I tried to put it into park from drive the gear shifter would not go up so I pulled shifter down into first which it went down fine but now it's stuck in the 1st gear spot. I had to disconnect the battery to get shifter to come up so I could remove my keys I tried to see if it would go into park this morning but the gear shifter just go up and down now and will not engage the Transmission. My fluid level is good there's no check engine light on and there was no warning of a problem any help would be appreciated.
Thank you in advance
