hello all
have a 04 2500 2wd 180,000 ml
towing a 7,000 5th wheel
5.7
nv4500
4.11
thinking about building engine
looking for thoughts on ether stroking 5.7 or doing a 6.1 swap local engine builder recommended the stoker for the torque
Did you put in a 4.11 or is the OEM 4.10?
A 6.1 would give you a bigger bore to work with IF you were gonna stroke that; stroking the 5.7 automatically gives you a longer stroke (6.1 and 5.7 have the same stroke, just different bore size). The same crank you would use to turn a 5.7 into a 6.4/392 turns a 6.1 into just about a 426. Between a simple 6.1 swap or stroking the 5.7, you're ahead of the game with the 5.7. 6.1's are getting harder to find these days. If you try to use a complete 6.1 long block you run into other troubles as well.
my mistake oem 3.73 gears thought i was told when i bought the truck new it had 4.10 never looked at sticker i'm looking for the longer stroke for more torque, bigger cam better heads and intake
Related Threads
DodgeTalk Forum
4.7M posts
289.9K members
Since 2002
