Stock Throttle Body 5.2 50mm?
19985 Views 10 Replies 6 Participants Last post by  dodgefan360
I was wanting to know the stock size of the throttle body of the 318 5.2L. Is it 50mm? also, is the r/t 360 5.9 stock throttle body the same size as the 318? Thanks.
1 - 11 of 11 Posts
anyone?
Call Dan at www.thefastman.com he could tell you.
The stock throttle body for all Durango's with a 5.2 (318ci) or 5.9 (360ci) is 48mm (this includes the R/T as well). The ported stock throttle bodies that Fastman sells is a 50mm or 52mm. Hope this helps.
Ya what MagnumD said. I have read that the fastman bores the 5.2L throttlebodies out another 2mm....so if that makes it a 50mm then the stock size is 48mm.
Sorry to hijack this thread, but DodgeEnthusiast I was wondering how much space you have between the top of your air cleaner and the hood liner above it. Thanks
I would guess somewhere between 1/2 inch to 3/4 inches. I tried putting a 3" air cleaner on and I basically had to squash the hood onto it. If you're going to get a round air filter I would suggest trying to find a 2.75"...that would probably be about perfect. My plan is to get a 3" PA body lift and the great side effect would be added clearance for a bigger air filter!:D
The reason i asked was that there was a 50mm one on ebay. After the auction ended he said it had been ported. He didnt put it in his description though. So i thought it was the stock. The 50mm ported tb ended up selling for 31 bucks with 15 bucks shipping. I messed up on that one!!!!!
throttle body
i got one from fastman . it was a 360 bored out to a 55.5 mm runs great. now iam looking for a 360 computer off a 89 ram.hope it will help even more.
throttle body
is there anyway to convert or to know about what size throttle body is compared to a carb. like how many cfm is a TB 55.5 mm????????
www.thefastman.com
I couldn't find any CFM numbers for V8's...
From allpar.com (Neon section 4cyl):
49mm TB flows 252 cfm
52mm TB flows 283 cfm
55mm TB flows 317 cfm
60mm TB flows 377 cfm
I read this a few days back on a GM site V6 section (I have a Pontiac):
65mm=2.56" = 5.15sq/in = 480cfm
62mm=2.44" = 4.67sq/in = 435cfm
58mm=2.28" = 4.08sq/in = 381cfm
56mm=2.20" = 3.8sq/in = 354cfm
52mm=2.05" = 3.3sq/in = 308cfm
See less See more
1 - 11 of 11 Posts
