is their any way i could fit half worn 305's on a stock 94 1500. becous i really dont want to get a lift
I don't agree with the logic. The Goodyear MT/R 305/70 for a 17" rim is 34.1" and for a 16" rim it is 33.1". So if they rub on an Off Road with 17" rims AND 2" of additional height, then they should also rub on a standard 4x4 with 16" rims and WITHOUT 2" of additional height because the difference is only 1".whiteram4x said:"There are poeple running them with no lift but they will rub bad. They rubbed on my Off Road version so I KNOW they will rub pretty bad on a standard 4x4. The MTR's in a 305/70 come out to about a 33-34" tire.
A 315 is closer to a 35" tire."
You can run them fine if you have a 16 inch rim. He has a 17" rim and the 305 for 17" rims are actually 34" tires. A 305/70/16 is only about 32.8 or9 inches tall it will clear on a stock wheel. :thatfunny
Yes, I understand all of that. However, it makes no difference, the only thing that matters is the OVERALL diameter which on the 16" is 33.1 and on the 17" is 34.1, that is per Goodyear. I still say they will rub the inner fender and the control arm, it is a given and others will tell you the same based on experience. A 33" tire on a stock 4x4 Ram rubs during regular driving when you turn the wheel to the locks.whiteram4x said:Quote:
The 305 is the width of the tire. The 70 is the percentage of the width that makes up the side wall height. Therefore a 17 inch rim will require a 1inch taller sidwall to have 70 percent the width of 305. In turn a 305 70 16 will be an inch shorter because 70 percent of the 305 on a 16 inch rim is 1 inch less than a 17inch rim. I have seen a ton of stock dodges around my town that have 305's on stock dodge 16inch wheels. They don't appear to rub on the street. They probably will if you offroaded it much but I bet it will only rub the control arm. That will not hurt A thing. All this would also depend on the condition of the front springs, trac bar, etc. and the tire manufacturer. But I fell like you should clear them fine especially on the street.
