1 - 3 of 3 Posts
This morning when I started my '94 Grand Caravan, 3.0, the starter would not disengage. Had to disconnect the battery cable. After sitting a while I would reconnect the cable and it was still engaged. I have 293,841 miles on it, never had a valvle cover or oil pan off. This is original starter. Is the best place to start changing things the solenoid? Is the starter solenoid built in to the starter or is it seperate?
Thanks.
Do It In A Van
The starter solenoid is built into the starter.
With almost 300K on the van, I would just go ahead and replace the starter.
Thanks, Nate
That did it. When I was disconnecting the lead to the solenoid the lug fell off! I guess I got my moneys worth out of this starter.
Thanks, again.
Steve96
1 - 3 of 3 Posts
