i have a 97 ram 1500 4wd with the 318. it starts up fine then cuts off. only when its cold. even if i crank it up and give it a slight rev or hold it to about 2000 rpm for 2-3 seconds. but one it gets warmed up she will drop right down to idle like nothing ever happend. it has gotten worse over the last month it used to crank and idle and drop then idle and drop. or if i would put it in gear it would die, unless it was wormed up
any ideas
i just replaced the spark plugs, wireset, distributor cap, and rotor button hoping it would cure the problem.
seems like its a sensor any help would greatly be appreciated
i have a didgital mutimeter if you can tell me how to do some testing of sensors
also there is no check engine light
any ideas
