1 - 6 of 6 Posts
I drive a 1999 durango...318 CI..Problem is after driving for any amount of time it stalls..I took it in to a dealer that told me it was fuel pump related and changed out the fuel sending unit. That did not solve the problem.Has anyone else experienced this problem and if so what is the cure?
Do you get a check engine light or a No Bus flash? Does it start right back up or takes a while?
mine stalled out when cold and was helped with gumout carb cleaner at throttle body cause dirty air idle motor.
engine is warm.. it happens after I've been driving for a while..I don't get a check engine light either. it has to sit for about 5 minutes or so before starting again.
This started after I had my vehical serviced with an oil change and air filter the air filter was replaced.
I would do a search on the No Bus problem. The symptoms sound the same.
Keystoner
probably just a dirty IAC. mine did the same thing. pull your IAC behind the TB. you can clean it or just change it out. I changed mine out.... hope that helps
1 - 6 of 6 Posts
