We shall see...its doable but i think that the side kick up of the 09 fascia in first pick on the side,near the directional will have to be laid down,like todays 02-08 model...i will just have to bring the line up as tight as possable to bottom of headlight,this way i can gain the 1/2 inch towards the grill shell with the fascia,so that the fascia line matches over near the grill line...otherwise the top fascia would be off.Its hard to explain...this headlight area has lots up lines that must match up as in straights,angles and vertical lines.The end point of the headlamp,near the directional would go directly into the metal side of the fender,there is plenty of meat there....just look at the 07- 08 headlamp takes up the metal side.
Obviously the top of the fender must be cut and raised to accept the lenz,the bottom of the headlamp is the key,it must not go lower than the metal side of the fender...everything else can be massaged.
