1 - 2 of 2 Posts
I've a 85 d150 and a 95 jeep cherokee. I'd like to use the same wheels and tires on both. What problems would I have with installing cherokee steering knuckles/spindles on the dodge's control arms/ball joints. Also I've no ideas on how to do this on the dodges back wheels. Any advice would be great!!
Tim
I don't know what bolt pattern your jeep uses but i think its the same 5 bolt as a ford or newer dodge, if so ive done this swap to my 82 dodge, changing it to the larger bolt spacing found on 86+ dodges, the front rotors are a straight swap, and the rear axles were changed out with no problems, Except I had to change the rear brakes from 10" to 11" as they don't make 10" drums for the larger bolt pattern.
1 - 2 of 2 Posts
