Is there any truth to this?? Found via a google search but something with the sizes of the speakers and their locations dont seem right...I have a Crew cab and I don't see why the 6x9's would be in the front? I am adding a In Line converter this weekend and want to run it behind my head unit instead of adding a ton of wire to the converter itself....
Car Radio Battery Constant 12v+ Wire: Yellow/Red
Car Radio Accessory Switched 12v+ Wire: Run a wire to the steering column and use the Dark Blue/Pink wire in the ignition switch harness.
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: N/A
Car Stereo Amp Turn-On Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6″ x 9″ Speakers
Car Audio Front Speakers Depth: 2 3/4″
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Car Audio Rear Speakers Size: 5 1/4″ Speakers
Car Audio Rear Speakers Depth: 2″
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Dark Green
Left Rear Speaker Negative Wire (-): Gray/Light Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
