1 - 7 of 7 Posts
Anybody here got the Ft/Lbs Torque Spec for the Spark Plugs for the 4.7? I'd like to properly torque them down.
Got 2 Hemis
On the Hemi, it's 13-15 ft/lbs. Probably the same on the 4.7. Aluminum heads, you know. What many of us use is "finger-tight" plus 1/16th turn.
20 Ft-lbs Bro!.
Discussion Starter #4
Thank ya both!
Discussion Starter #5
I think it was time for a change, looks like they were in there all 94,950 miles:
New one:
Engine:
Top of air assembly on:
All on:
Tightened them down to 15ft lbs with my Torque Wrench.
Ramistered User
The method I use, including the anti seize on the threads.
The problem with t/w here is that if the wrench fails to click or the threads in the head are not 100% you run the risk of stripping out a hole and that could happen very easy! I do mine like mentioned above bottom out and 1/16 of a turn maybe a little more and your good to go.
1 - 7 of 7 Posts
