Hey guys, I'm rethreading my spark plug hole at the back left of the engine using an OEM spark plug repair kit. It looks good but there's a problem, the tap that it came with has a head for a 16/17 mm socket to go on and when the socket is on the tap the space around the SP hole is too small for it to fit all the way to the bottom. So I can tap it about half way and then past that the space gets too tight for the socket to go any further. Just wondering if anyone knows where to get a tap that is either extended (where the tap shaft is longer and the socket head higher/further away from the hole) or one that has a hole in the head for a drive extension (1/4, 3/8 or 1/2). The taps that come with the heli coil sav a thread kits has a tap with drive extension hole but can't find it anywhere in Canada, where I am. Appreciate any advice or info, if I can't get around this issue she's gonna have to be parts aha
