1 - 2 of 2 Posts
I just installed a rebuilt Solex Mikuni carb on my 87 dodge ram 50 2.0 pickup.
I had it tested and it came out as gross polluter again. Everything has been changed...carb, cat, oil, plugs, dist cap, air cleaner.
I think the carb is running rich but I dont have the manual to adjust it.
Anyone know how to adjust this carb? Or where I can find the manual?
Thanks
Rc
I have messed with a few of those carbs and will never again. they are mechanical and vacuum nightmares. I would highly recommend you take it to a shop to have the engine looked at. You could still have a weak ignition system, make sure your battery and charging system are working correctly, EGR valve working ok, Do you have the correct thermostat installed-if it's too cold it will cause higher emissions.
Post the results of your emissions test with your readings and the pass/fail specs so we can see better into your engine.
1 - 2 of 2 Posts
