Hello, I tried to edit this in to my other post about code P0760 but the edit feature is not working for me. My additional question is, when replacing the solenoid pack, does anyone know if the factory uses a gasket or do they use that silicone type sealer? I will be using the gasket when I replace mine, but I wanted to know if I was going to have to remove factory sealer. I hope not, as it is in kind of a tight location. Has anyone changed one? I have a 2000 Caravan, 3.3L. Any help or info is greatly appreciated. Thanks, Randy
