Hello, I replaced the shift solenoid pack in my 2000 Caravan and everthing is back to normal now. It is shifting smooth. My problem was code PO760, shift solenoid c malfunction. I found a brand new Borg Warner solenoid pack on ebay for $95.00, It was from Oregon Transmissions, they delivered it in 2 days. The new replacements look a little different than the original one, but they are a new style that is more quiet than the old ones. When installing the new one you can throw away the plate that is between the 2 gaskets and just use the one new gasket that is provided, also you don't need to reinstall the rubber boot cover over the new ones. The install went fairly easy, it can all be done from the top. I would recommend washing the area around the solenoid prior to removing it so no debris gets in the tranny. Procedure is pretty straight forward, Remove air cleaner tube, 2 flexible tranny lines, sensor that is above center bolt, electrical plug on top of solenoid, remove 3 bolts. I hope this helps anyone that needs to do a replacement. It was about a 3 hour job, (not having done one before).
