1 - 3 of 3 Posts
98 dodge ram 1500 5.9 engine. Has new injectors and recently had oil change. It blows so much smoke when it's started you can't see the trees around it and it's worse when you give it some gas. Once it runs for 10-30 minutes to warm up it's perfectly fine, has all kinds of power. Completely stumped as to what it would be.
could b leak down from the valve seats or valve guides. must be the heads. just the usual suspects. have the compression checked. prolly not the rings..
1 - 3 of 3 Posts
