1 - 15 of 15 Posts
Tricked out Ram
Not your normal mildew smell. This is almost like fresh silicon. The pass side floor is dry. No sign of coolant loss.
Any ideas?
Ramistered User
Is is more prominent with the a/c on, recurculate on? Wonder if its refrigerant or a mold and mildew?
Have you had any dash work or a/c work done recently ? The last time I had my blend door fixed for the third time the tech jacked my dash around after the a/c was hooked back up and caused a leak. I had the same smell as you are talking about.Ofcourse the dealer denied it and that is how I traded it off .Forth blend door broke and all smelly.
02 R/T & 05 Ram
Freon/Compressor oil ? Maybe a leaky evaporator ?
Tricked out Ram
Discussion Starter #5
Smell is there even without the AC. Is it strongest when you first get in and turn the fan blower on. I guess I'll try some Lysol and see what happens.
02 R/T & 05 Ram
Is your outside drain tube clogged ? It exits the firewall right behind the right head. Any wet carpet ? This clogged drain tube is a common issue on the Dakotas
Tricked out Ram
Discussion Starter #7
Carpet is dry, drain tube leaks as it should
Sprayed some Lysol today on the exterior vents by the wipers and ti is much better. I guess it was a bacteria or mold after all. Im glad because I really didnt want to tear my dash apart.
\m/(-_-)\m/
Use some Ozium works really well.
02 R/T & 05 Ram
Ozium ? Old stoner, eh ? LOL
Tricked out Ram
Discussion Starter #11
Looks like the Lysol did the trick. No more weird smells.
02 R/T & 05 Ram
you should try cutting down on the burritos as well :nono:thatfunny
Tricked out Ram
Discussion Starter #13
^^^ yeah because farts get absorbed in those seats easily
Admin - David Mack
Your lucky. I had to clean mine two times with the A/C duct cleaner.
1 - 15 of 15 Posts
