I have posted this on another forum, but want to try and see what people here are experiencing as well. I have an 09 Crew Cab 4x4 with the 5.7. There is a slight vibration in the truck when driving. It's most noticeable in the 1500 to 2000 rpm range and can be felt the most through the gas pedal while cruising at steady highway speeds or very light load on the engine. It's not a tire balance issue as it's a completely different feel. Best way I know to describe it is imagine somebody taking a hand held massager and holding it under the gas pedal while you are driving. Is almost like a buzzing sensation.
I believe the vibration is there constantly, just that it's most noticeable in the lower rpm ranges. You can also feel it through the steering wheel and the floorboard, but not as much as through the gas pedal. You do have to be somewhat sensitive to things like this in a vehicle or you might not even notice it. If you wore boots you may not feel it either.
I'm almost 100% positive it's not MDS. You can still feel it when in ERS mode or tow/haul mode (these disable MDS).
So I'm curious to see if others here have noticed this or not. If you have, please post the specifics on your truck that could possibly shed some light on what model configurations may be affected. I will post my info below.
I have an 09 Crew Cab, 5.7, 4x4, 3.55 gears, adjustable pedals and a build date of Oct. 08.
