Hehe, well each to his own I guess. Starting fluid/ether and carb spray work the best IMO because they make a more noticeable difference when sucked in, but the other stuff works too. I guess it's like engineers torque their wheels on, the rest of us just zap them w/ an air gun or crank them down w/ a 4-way or breaker bar. Both ways work just as well, one is just the "certified correct" way to do it.
However, back on topic
I'm having a similar problem w/ my '80 S6 w/ a 2-bbl swap. It came swapped, but the carb was junk (reman'd improperly). I'm running a V8 Holly 2280 on it, and I think it is too rich, and also the balancer may have slipped the outer ring. Tried setting the timing at 10-12, ran okay but stuttered bad when I gassed it. I just twisted the dizzy up till the idle sounded better, ran it around the yard (no tags) and got on it, spits back a time or two then goes. I think the timing is somewhere around 18-20, maybe 22 according to the timing tab, so I'm pretty sure the ring is slipped. I haven't tried disconnecting the accel pump yet, did disconnect the vac adv and it got worse. Also, when idling, it'll idle good for a while, then start missing, like a plug or wire died. Revving it will usually clear it up for a bit, then it'll go back to missing. If I let it idle for a long time, it'll sorta clear up a bit also. I've swapped ECU's (has an orange Mopar ECU now), dizzys, plug wires, caps, wiring harness, and has new Autolite copper core plugs gapped at .035".
