1 - 3 of 3 Posts
I'm lowering my 95 ram it was a 2/4 drop it should end up being a 6/8 when I'm done after the suspension s done I'm swapping in a 78 440 with a 5 speed anyone know what shocks would work that low can't seem to find any
audio is my game
i would think your going to have to throw stock coils in and just cut them till you get the height you want. if you want to get really technical about it you can look at the spring rate of your current springs. then compare the weight of a 440 to the...id assume 360 and see the difference. i know its not what you asked but it something to think about when swapping engines.
as far as shocks.....bell tech has good shock options. im gonna guess you did drop coils and spindles? so you dont need 6" drop shocks you just need the length of coil drop. im running a set of 2" drop shocks and there working but are at the end of their life and getting a little bouncy. ill likely go with the belltech ones as a replacement when i need it.
1 - 3 of 3 Posts
