Good evening everyone,
Tonight, as I was just starting to back out of a parking spot slowly, I felt a shudder. Almost like I was dragging something or a vibration. There wasn't anything there under the truck that I could see. I just turned on 10,000 miles today. It felt like it came from the rear. It's not done that before and didn't do it anymore after I came to a stop.
Any ideas? U-joint? Differential? Suggestions? I'll make a appointment to bring it in-it was just too weird.
Thanks,
Nell
Mine also does that as does my friend's '03 2500. I'm thinking it's the exhaust vibrating with the engine at low rpm light load. Just a guess but with his at 98k miles and mine at 45k miles and no ill effects, I wouldn't consider it a problem.
Thanks,
Nell
http://dodgeram.info/tsb/2004/03-003-04.htm
"Symptom/Condition:
A vehicle may exhibit a drive line shudder or vibrations while accelerating from a stop. The
condition is most noticeable under heavy throttle acceleration and is usually only present a low
speeds (below 25 m.p.h.). "
Good thought but different symptom. I hesitate to call either a problem because neither is a problem. Just a slight momentary vibration.
