i am getting true duals with spintech prostreets put on my o5 hemi ram on friday would an x pipe make it louder or help performance any
You are going to need either an X pipe or an H pipe. I think the X pipe would have less restriction and better airflow. I would go with the X-pipe.
hot2k1ram
an h-pipe (balance tube) might be a better choice on a truck because you can get more drive shaft clearance by bending the pipe into a curve so your shaft doesnt hit the pipe, an x-pipe cant be bent to make clearance for a drivesfaft if you're running true duels. and it's a highly debated issue with x and h pipes, but i work at an exhaust shop down here in louisiana and have found that h-pipes generally make the car or truck run better, h-pipes are just pressure balances anyway, equal pressure on both sides of the exhaust will make the power seem smoother and both banks of the engine will be running equally
