I decided to post this question here because it appears that this forum gets more looks then the ramcharger forum and I don't think there's that many differences between the RC's and the trucks anyway.
I have an 84 RC 360 / 4bbl and it's time for either a rebuild or just swap in a magnum crate engine. I did notice however, that mopar offers a reman 360 RV shortblock that they say is perfect for trucks/vans. I figured that just buying the shortblock and swapping over my existing components would be cheaper then purchasing a crate engine, but I'm not sure if it's worth it in the long run. I do like the magnum engines and it seems like everybody is swapping out their tired old "LA" engine for the magnums, but I've read that a properly built LA style block can perform just as well if not better then a magnum.
Also there is one thing that I have yet to get a clear answer for and I've looked all over. In the mopar catalog's description of the 320hp 360 Magnum Crate engine, they all say "Not for use with air conditioning". The closest thing I found to an answer was in a Chrysler performance book of mine and it said when installing a magnum engine it's possible that the A/C comp will not bolt to the engine and some fabrication may be needed to make it fit... However, I couldn't discern if was talking about swaping it into a truck or into a 70's era muscle car...
So if anybody has any advice on which route to take and if the A/C can be used with the magnum crate engines I'd really appreciate the help....
