Super simple question, but I'm having a stupid amount of problems locating a serpentine belt for my 96 Ram 1500 with 5.9. I've gotten 2 belts, 1 too big, 1 too small. Does anyone happen to have a part number for one they have replaced?
I recently purchased a 98 dodge ram 1500, standard transmission, 5.2L 318, 4 x 4. I've already done some work on the truck... Most everything to do with the cooling system. After replacing the water pump I had a friend tighten the negative battery cable. Since then I can't keep the battery...
Misfiring cylinder 7 changed all the coils spark plugs fuel injectors. N still misfiring on 7 I take the plug out on 7 n they came out black carbon..dry.i Need help in fixing my truck.??
I changed out the fuel pump unit in gas tank After sitting overnight I turn the key halfway and the sender unit is pressurizing rail for over a minute, then starts right up. Why does this pressure rail take so long to build pressure? The old fuel pump had the same problem. I changed out fuel...
Howdy, I have a 1995 dodge ram 1500 4x4 5.9l v8. I just recently bought it and I want to do a tune up on it. Plugs, wires, coil, cap and rotor. after studying High Performance Electrical and Air/fuel delivery, I found out how beneficial a MSD box is. With that being said Is there any one out...
