1 - 7 of 7 Posts
· This Space Left Blank
Just to throw this out there. Has anyone installed a second battery in their truck?
· Registered MOPAR User
KYKillerKlown said:
I have a Optima Redtop in the engine bay and another Redtop and a Gelcell battcap in the bed.
How did you run the recharge circuit, off Alt or direct to 1st batt?
· They call me Radio
I have 2 batteries in the bed of my truck. I run a battery isolator to charge them up because they are deep cycles. You should only charge your second battery off of your main battery if they are the same battery. If they are different, they will drain each other. A battery isolator is the best route to go if you are using your second battery for accesories like power invertors, winches, ect... A kill switch for your second battery is always good to have on board as well.
If you can put a second one under your hood, I highly recommend it. This involves removing the airfilter box. I've heard that you can take the 2nd battery box off of the CTD and install it there. If not, be prepaired to dump some money into the appropriate cabling to make it to the bed or to a battery box attatched to the frame.
Just curious, what are you wanting to do with a second battery?
I am going to be setting up some electronics. An audio upgrade with two amps, a computer installation, a few LCD Screens, some cameras.
I want to run it off of a secondary deep cycle battery, so that I can run them while the ignition is off without the risk off draining the main battery.
I did notice the the holes are in the passenger side to install the second battery box, but the air intake is blocking the way. any thoughts on how to get around this?
Basically, you have to get a new intake or make your own. The airfilter box has to be completely removed to get the other battery in there. Problem is that most aftermarket intakes run through this area. That is the big reasons I don't have one up there. There are a couple of the cheap intakes on eBay that put the filters above the engine. You could also just purchase the individual pipes and piece something together that routes around your battery... or get a shaker hood :D
1 - 7 of 7 Posts
