Is there any simple method to bypass the seatbelt circuit without tampering with wires or such. The chime that rings when the seat belt is not fastened is annoying.
I was thinking of buying a buckle at a junkyard to just complete the circuit but didn't know if there is any quick fix to bypass the circuit.
Thank you,
I think the best way to stop the chime it would be to actually wear the seatbelt.
but other than that i guess the only way would be to trick it with another buckle or something
on my old pontiac grand am I could unplug the sensor in the buckle from underneath the seat and get rid of it. but i left it plugged in anyway because i wear my seatbelt
steps to disable seatbelt reminder chime
from page 56 of the '07 GC SXT owners manual:
Belt Alert Programming
The Enhanced Warning System (BeltAlert) can be enabled
or disabled by your authorized dealer or by
following these steps:
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the
ON/RUN position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System (BeltAlert).
1. With all doors closed and the ignition switch in any
position except On or Start, buckle the driver’s seat belt.
2. Turn the ignition switch to the ON/RUN position
(engine does not need to be running), and wait for the
Seat Belt Warning Light to turn off.
3. Within 60 seconds of turning the ignition switch to the
ON/RUN position, unbuckle and then re-buckle the
driver’s seat belt at least three times within 10 seconds,
ending with the seat belt buckled.
NOTE: Watch for the Seat Belt Warning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt each time,
while unbuckling and re-buckling the seat belt.
4. Turn the ignition switch to the OFF position. A single
chime will sound to signify that you have successfully
completed the programming.
