1 - 13 of 13 Posts
Rollin' on 20's
Today I had a little extra time to kill so I decided I should give the gift of Seafoam to my truck. It's a 2004 4.7 w/ just over 48K miles. No codes have ever shown up before now, but when I took my truck out for the throat clearing drive, I noticed my CEL on. After I got back and looked around on here a while to find out how to check my codes, I found out that I was getting the P0300 code. I haven't changed my spark plugs before so I'm thinking that running the Seafoam through may have just made my 18K overdue spark plug change a higher priority.
Anyone ever get this code after doing the Seafoam routine?
TIA
Beardking
i dont know about the code, but i'm pretty sure when seafoaming it, they tend to mess up the oxygen sensor
Edit: same situation came up for my jeep and i replaced it and error went away.
You'll have a couple misfire codes... that stuff makes it run really rich, and when you start to drive it, it will foul the spark plug out some.. cause a misfire.. just clear it and keep driving..
'11 5.7L R/T Classic
unplug your battery...
Change the plugs, delete the code and drive the hell out of it.
Rollin' on 20's
Discussion Starter #7
Well, I changed the plugs (holy crap, I didn't realize how much I REALLY needed to buy a set of swivels prior to doing this) and now I have a p0113 code. I'm fairly positive that I know why. I think I forgot to reconnect the IAT when I was buttoning it all up. I'll have to look at it when I get home this evening and make sure.
me neither, but i didnt do it through the brake booster though.
Rollin' on 20's
Discussion Starter #11
I was correct. After all of the checking and re-checking, I boned it and forgot to plug the IAT back in. Plugged it back in, reset the PCM and then started the truck and all was good. Woohoo.
Premium Member
When I did the Seafoam with no problems. I think you kick-up something else while you were running the Seafoam.
:dunno:
1 - 13 of 13 Posts
