Does anyone in here have any experience or input concerning the SCT programmer? That is the direction I have been pointed in, but would appreciate any positive or negative feedback.
Thanks
Thanks
The SCT programmer would be the best way to optimize your specific combination, since your engine has a good amount of modifications done to it. The Superchips air-fuel ratio is not tuned to your level of modifications, nor would any other pre-programmed software upgrade. Your combination of mods are custom, which would require a custom tune to realize the full gain. JMHODoes anyone in here have any experience or input concerning the SCT programmer? That is the direction I have been pointed in, but would appreciate any positive or negative feedback.
Thanks
That is exactly what I am running into. I have a part throttle, under load, pinging problem that I believe is due to a too lean condition. I believe that I have taken my Durango as far as I can, or even beyond, with the Superchips programmer. I have purchased a new short block for my D, but do not want to install it until I get all the bugs worked out of my present setup. Also, when the new short block goes in, it will have a heavier than stock cam in it, which will cause the computer even more grief. My first plan is to install a wideband A/F guage to see where I am at. Then it looks like I will be getting an SCT programmer. I have realized that, the further up the ladder you go, the more expensive each rung is. Gotta love a well tuned engine.The SCT programmer would be the best way to optimize your specific combination, since your engine has a good amount of modifications done to it. The Superchips air-fuel ratio is not tuned to your level of modifications, nor would any other pre-programmed software upgrade. Your combination of mods are custom, which would require a custom tune to realize the full gain. JMHO
