Can anyone tell me if they have a Rumble Bee possible an 04 using an electric exhaust cut out? Where did you put the cut out? I know to get the best performance I should install the cut out before the cats! But their isn't much room under there. Should I move the cats a little closer to the rear and install a H-pipe setup with one cut out? Or should I use two cut outs. I'm not sure if the 04 regular Hemi has the same exhaust system or does it? Any suggestions??
