1 - 6 of 6 Posts
EPA's Worst Nightmare
I'm getting ready to install my 1.7 rr's on my V10. I have to get longer push rods so right now I currently have the left valve cover off (not fun on a V10). Once I get new push rods can I install the rockers on just one side of the engine then drive it with it half way done? Or would that do something bad to the engine?
Only reason I ask is when I do the right side of the engine the intake manifold has to come off to remove the valve cover. If I don't get them adjusted right I would have to remove the manifold twice and replace the gasket twice. Not something I want to do.
Thanks.
******* SPACESTATION
You would have one side of the motor producing more power (more downforce) on the rotating assembly. I doubt it would idle very well as 1/2 the valves are opening further longer, and the other 1/2 aren't.
I wouldn't do it.
And if you don't have the time / resources to do the mod correctly wait until you do before starting.
what is there to adjust? Did you purchase HS roller rockers or another brand? I didn't know they made adjustable roller rockers for out motors, but even if they did why would you want them? With a hydraulic lifter setup, there usually isn't a need for them as the lifters take up the minute amount of slack that would need to be adjusted out.
Mmmmmmmmm, beer.
Ya, Crower makes adjustable rockers. Viper rockers are also adjustable. Reason the HS rockers are not is because they are shaft mounted as a pair. HS also makes adjustable ones too, but I agree, why would you want to with the non adjustables being so easy, and usually less expensive too.
i wouldn't run the motor at all with half 1.7 ratio and i don't know for sure but i would think the V10 uses 1.6 ratio just like the V8? but if thats so i would just do both sides before driving the truck. why do you need longer push rods? you would need shorter lifters or smaller cam duration i think to have longer push rods. this would not let your valves close all the way. (not sure)
~Zack
I have crower. The reason I have those is because they are the only ones made for the V10 engine. I contacted HS and they told me that they do not make any rockers for the V10 only the V8.
The standard ratio for the rockers is 1.6 The ones I have are 1.7. Crower told me that since I have a higher ratio than stock I will need longer push rods. Other wise I will hear the lifters all the time. I don't know too much about engines mostly electrical and diagnosis so I was just taking there word for it.
Thanks for the info on the install. I will wait until I get the rest of my parts.
Crew Chief
I'd advise not following the rocker manufacturer's recommended valve lash adjustment procedure - we did that and ended up staying at the shop til 10pm to R&R the valve covers (PITA on the 8 liter) and adjust them the same way we do in the pits... by feel. :cool:
1 - 6 of 6 Posts
