1 - 9 of 9 Posts
I was sending my sir michaels roll pan to get painted today and was wondering if i need to mount it first to make sure there is no mods that need to be done to it. Any suggestions?
Thanks
Yea, It's a Hemi
Should have been fine. I havent heard anyone having any fitting problems.
Well when i picked it up the guy said sometimes he has to grind the edges. But i dont know other than that i'm assuming it should just be direct bolt on right?
LSU
mine was fine but i would just put it on first to make sure it fit right.. that would suck it if didnt fit right..
yeah i guess just to be sure i'll mount it first before getting it painted.
Thanks
Always test fit first...makes your life easier down the road. Plus you can look if you might need a few washers as spacers on one part or another. Or as said, could need a slight grinding etc to make it fit well. Best to grind first, then paint, rather than vice versa. :)
KB
yes , prefit it , get your holes drilled and all, better now then after its painted and scratch it...
Hemi2nV
yea i probably should of done that but it worked out for me....I had a tap and drill so I was fine. But your def gona need an extra hand to remove the tail gate, lift the bed (gona take 3 people), and mount the bumper.
PROJECT SRT-345
Yep, you need to make it as easy as possible, because like 440 said it will be painted. So you'll need it to go easy without any hiccups or I guarantee you will scratch it lol...
Jason
1 - 9 of 9 Posts
