1 - 7 of 7 Posts
Hi guys when driving there is a whine it is load and if i let off the gas it dies down? some one told me the flywheel may be warped? any thoughts thanks! :IDEA: :IDEA: its a 2002 b-150 starcraft conversion 318 i tow a 26 forestriver bhss i have 3:93 rear end
Do It In A Van
Hmmm I don't think it's a warped flexplate. If it was you would have one hell of a vibration.
A whine can come from aggressive tire tread, exessive lash in the rear-end gears, perhaps an axle or pinion bearing. Those are my guesses.
Do It In A Van
I was just thinking that a bad front wheel bearing may cause a whine too. But generally a bad front bearing will give a rumble or grinding noise.
Do It In A Van
It could be exessive lash in the rear end gears that is causing the whine.
1 - 7 of 7 Posts
