wesshipman said:
Ok on a 2500 with a 6in lift. What backspacing would i need to fit 37x13.5x17 tires. I mean obviously they wont be all the way under the truck. I want them to stick out a lil, like maybe 50/50 or maybe ever 2/3s under and 1/3 out. I obviously dont want them to rub. and it would be on a 17x8.5 or 17x9. anybody know anything about wheels as far as backspacing and offset, that could help me pick some wheels out. thanks
If you are going to run a 8.5" wheel and want 2/3 under and 1/3 out, you will want to find one with about 5.75" of backspacing (or +25mm offset)
If you are going to run a 8.5" wheel and want 50 under and 50 out, you will want to find one with 4.25" of backspacing (or -12mm offset)
If you are going to run a 9" wheel and want 2/3 under and 1/3 out, you will want to find one with 6" of backspacing (or +25mm offset)
If you are going to run a 9" wheel and want 50 under and 50 out, you will want to find one with 4.5" of backspacing (or -12mm offset)
Hope this helps!
