My Dak just recently started getting jerky in reverse. Almost like it wants to stall. Originally did it whenever I had the AC or Defroster on, now it does it randomly. This only happens in reverse. No noticeable problems in any other gear. Any ideas on where to start looking for the problem would be appreciated.
Stats:
1997 Dak, 2WD, V6, Extended Cab, ~120k miles.
History of components replaced so far (unrelated to this problem):
IAC valve
PCV valve and breather element
Water Pump
Thermostat
O2 Sensors
Brake Rotors
Catalytic Converter (under recall)
Fuel and brake line reroute (under recall)
Stats:
IAC valve
Water Pump
Thermostat
O2 Sensors
Brake Rotors
