1 - 3 of 3 Posts
Does anyone out there know a way to program Reverse Mirror Tilt & Easy Exit into a 2004 Chrysler T&C Memory System that I installed into my 2004 Dodge Grand Caravan . Reverse Mirror Tilt & Easy Exit are not Std on the Chrysler Mini Vans , but is found in most of the other Models.
There must be a way to Read & Write to the Memory Programs of the Modules??
If you installed all the components from a T&C it should be able to be turned on and off the same way as the T&C was.
Six pack
It would be that easy if the T&C ever had those options but they never did ???
It may well be impossible as all of the Chrysler reverse tilt mirror cars appear to use a 4 wire configuration on the 2 internal mirror rheostats , the T&C's only are using 3 wires ? As the command PCI signal comes from the overhead console to ?? , I need to be able to retrieve the program & possibably edit it to add these features as all of the seat motors only have a 3 wire rheostat . This can not be done with a DRBIII .
1 - 3 of 3 Posts
