Well finally figured out why my bed was sitting sooo low. One of the previous owners removed leafs. I sourced a new set of springs + shackles that I'm going to pick up this weekend (still need to get replacement struts b/c I'm assuming they're shot) but had a couple questions about install. Is it going to be easier to remove the tire on 1 side only, support axle, and do one side at a time? Or should I support both sides of the axle, remove both tires, then start working on swapping out the leaf springs? Also, based on the pics (with the lack of leaf springs) I'm assuming it's probably not safe to drive the truck? Any info is greatly appreciated. Thanks.
