1 - 3 of 3 Posts
I went into my fuse panel the one in the cab and the air bag fuses are different, how do you get them out of the little yellow casing? I couldn't figure it out. Anyone know? Hoping my air bag problem is something small, wishfull thinking :help:
I am yet to see a fuse in a yellow box.... Usually the yellow connections are special lock connections. If your light is staying on try unhooking the battery and then checking the yellow connections under the seats. Sometimes they will work loose and cause the light to come on.
· GROUNDED
its the IOD fuse, i had to change it because my interior lights in the overhead died along with the radio. i simply pulled it out and then used a paper clip to push out the fuse once i pulled the yellow thing out.
1 - 3 of 3 Posts
