1 - 3 of 3 Posts
2005 5.7 hemi, received first code for knock sensor replaced then tried to start no dice, then got crank sensor code replaced still got p0335 code replaced again to make sure didn't buy reject still got code, replaced connector checked for bad wiring and reset pcm, no luck anyone have any ideas?
audio is my game
this is the second gen section. you have better luck getting an answer posting in the third gen section.
As he says this is second gen but I'll help. See if you have spark and gas then I can narrow it down for you.
1 - 3 of 3 Posts
