I went with the Mopar, just to have the warranty and because I knew the electronics would be compatible for sure. Have had a minor problem with it which is know to DC - an arm (with a swicth or sensor) vibrates out of position (probably trying to get away from the Hemi), and has to be tweaked a bit occasionally, two second fix. Other than that, very good range and I'm happy with it.snobnk said:who,s got one? are some better than others?mopar etc... do some have better ranges on the remotes?i am putting one in soon and have just started my search.any help would be appreciated
You must not live somewhere that it gets cold.......Hemi Pete said:Personally I never cared for one. It is easy enough to start a truck...unless somebody wants to hand crank their vehicles again.
MOST HIGH END ALARMS ARE MADE BY THE SAME COMPANY NOW "D.E.I."snobnk said:who,s got one? are some better than others?mopar etc... do some have better ranges on the remotes?i am putting one in soon and have just started my search.any help would be appreciated
Viper is also made by DEIone short of said:MOST HIGH END ALARMS ARE MADE BY THE SAME COMPANY NOW "D.E.I."
BUT I LIKE THE VIPER FOR COST AND FLEXIBILITY .I HAVE THE VIPER 550 ESP WHICH I INSTALLED ON MY 03.
That would be correct . I was just saying that out of all of there alarm systems i like the viper but most of them are built the same now even some of the lower models are built the same way they just dont give you the ability to use them to there full ability .If you ever take apart some of the different remotes some even have the other function/second channel buttons on the board inside the remote the case is just different.lucky8926 said:Viper is also made by DEI
Oh, it gets cold in California...cold enough to snow anyway. However it isn't as cold as what you're thinking. That's why I live in the Golden State, I have no idea why somebody would wanna live somewhere deathly cold in the first place. :crazy:lucky8926 said:You must not live somewhere that it gets cold.......
Ahhhhhhh. I see. Well if you live where I live or north of where I live you would see the benefits of a remote start. You get up in the morning and there is a foot of snow outside and it's 10 degrees outside. You can figure out the rest...Hemi Pete said:Oh, it gets cold in California...cold enough to snow anyway. However it isn't as cold as what you're thinking. That's why I live in the Golden State, I have no idea why somebody would wanna live somewhere deathly cold in the first place. :crazy:
I was born and raised here. I'm not going to move just because it gets cold in the winter. We have a WIDE range of weather here. It can get below 0 in the winter and over 100 in the summer. We can have a drastic change in one day too...like today 85 at 2pm and 52 at 11pm. The temp dropped 20 degrees in 20 minutes!!!Hemi Pete said:Why do you like to live in such an environment? I don't wanna rub you the wrong way, but it is interesting nonetheless.![]()
